NLE Mac / Final Cut questions from 2002 - Page 48 at DVinfo.net
Final Cut Suite
Old August 28th, 2002, 12:56 PM   #706
That article was exactly what I needed
Thanks again for your help
Kevin
Kevin McCarthy is offline   Reply With Quote
Old August 28th, 2002, 11:52 PM   #707
DV input/ any format output?
Hi all:
I've run into a mental block here, and forgotten everything I know about digital formats :-) (Remember when you're writing something and suddenly you can't figure out what the right spelling of a word is? This is the video equivalent!)
1. Assuming I'm shooting on an XL1S, and digitizing to FCP, can I output my final film in DVCAM format on (say) a DSR-11 Sony VTR? Does input format have anything at all to do with output format beyond the limitations on image quality etc. imposed by the input format? (I've probably sorted this out in my head once already , but it's bothering me again!)
2. If I had to submit a final tape on Beta SP after shooting/digitizing from Mini DV, what would be the best way to do this? (Dump final cut to Mini DV/DVCAM and transfer at a post-house? I don't think I'll have access to an analog breakout box, so that rules out just hiring a Beta SP VTR and dumping straight to that. Also, I'm putting together a system that includes a DSR-11 VTR; and the DSR-11 only gives composite outs for a monitor.)
Thanks a ton!
Best,
Ram
Ram Nagarajan is offline   Reply With Quote
Old August 29th, 2002, 08:54 AM   #708
Jag on new machine.
Well, I may be in a slightly different position than many here. I opened up my new 17" iMac and found my copy of 10.2 on top of the box. I had been told that I would have to pay $19.00 for shipping (are they kidding?) when it became available, but the delay on the bigscreen iMac evidently coincided with letting the cat out of the bag.
Booted the machine last night, then immediately ran the 10.2 update. Comparisons are hard because my first FP iMac had a lower clock speed on the processor. This puppy is fast, but is it the marginal improvement in processor (700 to 800) or the improved OS? Who cares, it's great.
Office X installed without incident. I have been updating all of my title bar links and bragging about my new machine on my favorite forums...now I am going to start installing the rest of my software (PS-7, InDesign. Go Live) Hope they all go as smooth.
Got an underwater housing for my little ZR-50 and a dive trip coming up next week. Though I have real work to do, looks like the first editing project on my 17 will be a fun one.
Any questions about the 17" iMac, I will be happy to address them.
Only minor complaint so far is that all the extra real estate is in the width. Could have used a bit more heighth to go with it. I love it anyway.
Jeff Farris
Jeff Farris is offline   Reply With Quote
Old August 30th, 2002, 05:04 AM   #709
RED Code Chef
You can convert any input format to any output format as long
as you have the software that can read/write those formats
(or accepts plugins that can or something). Ofcourse quality
may suffer. Depending on what you do.
I cannot answer your other questions because I never have
outputted to Beta SP. DVCAM should in theory accept your
DV streams just fine.
Rob Lohman, visuar@iname.com
Old August 30th, 2002, 09:02 AM   #710
Rob, thanks:
From what you've said, perhaps I should refine my question a bit.
If I digitize to FCP 3 from Mini DV, but want to output my final film (i.e. print to tape) in DVCAM format, what would I need to do?
a) Would I need any additional software/plug-ins to convert DV to DVCAM in FCP 3?
b) Is it just a matter of popping in a DVCAM tape into the Sony DSR-11 VTR and printing to tape on it?
Anyone?
Thanks and best,
Ram
Old August 31st, 2002, 03:08 AM   #711
Read this as well...
If you run into more setup problems, try out this article:
http://www.kenstone.net/fcp_homepage/ambitious_beginning.html
FYI, here are the requirements for running FCP 3.02:
- Macintosh computer with a 300-MHz or faster PowerPC G3 or G4 processor and built-in FireWire
- 500-MHz or faster single or 450-MHz dual processor Power Mac G4 or PowerBook G4 required for G4 realtime effects
- 667-MHz PowerBook G4 required for mobile G4 realtime effects in DV format
- Mac OS 9.2.2 or Mac OS X v10.1.1
- QuickTime (included)
- 256MB of RAM (384MB recommended for G4 realtime effects)
- 40MB of available disk space required for installation
What rev iMac do you have?
Dan
Daniel Berube
Apple Certified Trainer
Member, Apple Consultants Network
President/Apple Ambassador
Boston Final Cut Pro User Group - BOSFCPUG
http://www.bosfcpug.org
Email: dberube@bosfcpug.org
noisybrain. Productions
digital_storytelling/
DV Consulting & Training for Business, Education and the Arts
http://www.noisybrain.com
Daniel Berube is offline   Reply With Quote
Old August 31st, 2002, 11:48 AM   #712
Retired DV Info Net Almunus
Jeff,
Hey, thank you very much for that tip, Jeff! The symptoms described sure sound like mine. I never heard of the "gimp-print" drivers (the name sounds a bit derogatory but appropriate in my printer's case). I'm giving it a whirl today and report back.
Old August 31st, 2002, 01:01 PM   #713
RED Code Chef
As far as I understand it DVCAM only differs in the tape format
used. The digital stream is the same. So yes, if you have a
DVCAM recorder you should be able to just print to tape to that
device and all should be well.
I suggest trying it out before commiting to it though. When things
need to work together it not always works as it should. Better
safe than sorry!
Old August 31st, 2002, 02:14 PM   #714
Thanks for the additional info Dan.
I am running a "Snow" iMac.
Power PC G3, 500 MHz, 256 RAM.
I know that I will need more RAM for 3.0, but are there any other issues I should know about?
Kev
Old August 31st, 2002, 06:01 PM   #715
Let's start here...
Do you have Peak DV installed on your computer yet? Are you on OS 9 or OS X? If OS X, are you on Jaguar? I ask because it helps me to suggest which software to use.
Daniel Bérubé • BOSFCPUG
Old August 31st, 2002, 06:17 PM   #716
Only 1 incident so far...
Here on my end, Jaguar installed like a charm on my dual gig, annd the resulting performance is extremely pleasing. Logging in time is reduced, and the performance overall is faster. The only incident I experienced so far was with attempting to quit FCP on one occasion when I finished editing. I selected "Quit FCP" and it proceeded to hang with the 3D lolipop icon tot he point where I keystroked a force-quit on the app; however, as soon as the force-quit window appeared, FCP quit before I could select it in the pane to quit. It only happened once.
I am in no way dissapointed by the release of Jaguar.
Old August 31st, 2002, 06:21 PM   #717
You can play and roll...
Jay,
No question here is a bad question!
I asked a rep about your deck and yes, you cannot control the VHS part of your deck, but you can print to video by playing the timeline and manually rolling tape on the deck via firewire. Not bad for this model at the price point it has. I am tempted to pick one up as a complimentary deck to my editing suite. I've seen SVHS dubs made off the deck from miniDV and the results are fantastic.
Old August 31st, 2002, 06:35 PM   #718
You will need patience but...:)
Kevin,
You will need to realize that you will not have realtime effects with your present setup, though you can still definitely edit with it, either set up to run in "Standard" or "Cutting Station" mode.
I have often used my iBook dual USB 500mhz on the road to digitize to and edit with, and am repeatedly satified with its' performance in straight cut and simple dissolve editing. However, when my editing tasks become more complicated, I resort to my dual gig tower to complete the job.
But I will never get rid of my iBook, because it has saved me in editing situations so many times. I can use it to digitize footage to my external firewire drive and at the same time continue to edit on my dual gig. Lats week I had to rent a DSR-11 deck at a rental shop to digitze PAL footage to my FireWire drive, and the iBook did the job with no problems on location, saving me money from having to pay extra to take the deck home.
So although our 500mhz G3 macs will never do RT efx, they will always be able to be used to digitize to and to edit in cutting station mode.
I absolutley recommend, though, that you also purchase at least an external 120 gig 7200rpm firewire drive. I recommend OWC's Mercury Elite series with the WD 120 gig 2mb or 8mb buffer drives. You can learn more about them at:
http://www.macsales.com. Then, in prefs, select the external firewire dirve as your main scratch disk, and go to it.
Happy editing, and let me know how it works out...
Old August 31st, 2002, 06:44 PM   #719
Here ya go...
<<<-- Originally posted by Ideosync : Rob, thanks:
Anyone?
Thanks and best,
Ram -->>>
FCP is a pixel pusher. So, as long as you have the proper in/outs/ b.o.b., hardware cards to support the print to tape, you're in business.
To answer your questions, you do not need anything other than a DVCAM tape and a DVCAM deck.
Did you say you own the DSR-11?
Old August 31st, 2002, 07:02 PM   #720
yes
10.1.5
no
Mark Reidy is offline   Reply
