60p and Final Cut at DVinfo.net
Final Cut Suite
Old June 26th, 2007, 07:24 AM   #1
60p and Final Cut
Sorry guys, haven't been here in a while.
I am wondering is there anyway to edit HD100 footage shot at either 24p,30p or 60p in Final Cut if I need the output to be 720p60.
I hava a client who wants to run an ad on the big screen at a local theatre and they requested 720p59.97 or 1080i59.97.
I do not have a Kona card, just a G5 with the basics.
Any help would be appreciated.
alex
Alex Menendez is offline   Reply With Quote
Old June 26th, 2007, 07:58 AM   #2
What is the delivery of the final product?
If you had a Decklink HD card you could shoot in HDV 720p30 do your edit in FCP and then export from the timeline out the Decklink card. The card will make the signal 720p60. You could then rent either an HDCAM or DVCPro HD deck and make your master tape.
Dan Weber
Daniel Weber is offline   Reply With Quote
Old June 26th, 2007, 11:39 AM   #3
Or output a Quicktime in Black Magic Codec and take it to a post house with HDCAM. There are a ton of post houses I assume in Orlando.
David Parks: DP/Editor: Jacobs Aerospace at NASA Johnson Space Center
https://www.youtube.com/user/JacobsESCG
David Parks is offline   Reply With Quote
Old June 26th, 2007, 12:20 PM   #4
This is very easy to do in Final Cut Pro. Just create a 720P sequence (say as AIC codec) and then manually change the frame rate of the sequence to 59.97.
You have to do this BEFORE you edit any clips into the sequence. The frame rate cannot be changed on a sequence that already has clips in it.
You can now edit your clips into this 720P59.97 (aka 720P60) sequence and the appropriate pulldown frames will be automatically added. If you have FCS2 (FCP6) there probably won't even be any rendering required as you edit.
On the flip side, if you are editing natively (with FCP5.1.2 or newer) you can still work in 24fps or 30fps as you normally would and then output ("Print to Video") your sequence back to the HD100 or the BR-HD50 deck.
Since the ProHD cameras always record the stream in 720P60 (or 720P50 in the case of 25P) and pulldown is automatically added to the stream, you won't really have to think about it.
You can then re-capture your edited sequence from tape as a m2t using DVHSCap or HDVxDV and it will be in 720P60 with the appropriate pulldown (as if it was camera original.)
How is it being shown? Does the theatre have some sort of hard drive based media server system? If so, m2t is probably ideal.
Tim Dashwood
Old June 26th, 2007, 01:12 PM   #5
thanks
thanks to all, I will keep you posted on the outcome.
alex
Old June 26th, 2007, 01:20 PM   #6
Let us know if output (for display) is tape based or a server- I'm curious!
Justin Ferar is offline   Reply
