Trashing Preferences at DVinfo.net
Final Cut Suite
Old June 15th, 2007, 12:14 AM   #1
Can someone walk me through the proceedure of trashing preferences. I have FCP 5 and have recently had a problem with FCP freezing up on me. Also when I shut down and reboot my external drives do not attach. I have have never trashed preferences and thought this might resolve my issues.
Thanks.
John J. Moon
www.northernlightfilmworks.com - Event DV Top 25 Recipient
John Moon is offline   Reply With Quote
Old June 15th, 2007, 06:27 AM   #2
I'm a relatively new user of FCP, so I'm no expert, but my understanding is this:
Go into your home folder, then open the library folder, then the preferences folder.
Delete the file "com.apple.final.cut.pro.plist"
Then scroll down to the FCP User Data folder, and delete
Final Cut Pro 5.0 prefs
Final Cut Pro Obj Cache
Final Cut Pro Prof Cache
Then empty the trash.
Also: Don't do this while FCP is running. And don't trash folders, only files.
Dave Lammey is offline   Reply With Quote
Old June 16th, 2007, 07:34 AM   #3
Thanks.
There is free program that will backup and restore your preferences for you. It also trashes prefs for you with a click of a button.
Set up your FCP system as you need, use this to backup a "good" set of prefs and then anytime you suspect a corrupt prefs, restore. It's available at
http://www.macupdate.com/info.php/id/14729
There is a version for FCP6, FCP5, and earler. Select the version of FCP you have.
HTH,
Grant
Grant Harrington is offline   Reply With Quote
Old June 17th, 2007, 06:29 AM   #4
Direct link: http://fcprescue.andersholck.com/
Chris Hocking is offline   Reply With Quote
Old June 19th, 2007, 11:53 AM   #5
Thanks for the help...on my way to get the download.
John
John J. Moon
