Problem with 1080i HDV to DVD (field issue)
I need a work around for the field issue apparent when down-converting HDV to DVD.
The Bonsai method <http://www3.telus.net/bonsai/Welcome.html> will not work, as there is too much motion and a side effect of the "fastest" conversion is that it gives a 3-d ghosting effect on fast motion in the frame. I can not convert to 720P60 or 480P, as FCP converts it to 30P and then doubles the frames, and the motion is jittery. I could dump it to camera and then down-convert in camera, but I have heard this is not a great method either. I have seen in another thread to save the HDV timeline in FCP as a HDV quicktime movie, and then import that into DVD studio pro and have it down-convert, but DVD studio pro says this is an "incompatible file". How do I get 1080i HDV footage onto a DVD so that it looks acceptable? |
The best de-interlacing technique is to "interpret footage" in after effects.
Make your comp, import your video, in the project window control-click on the movie select interpret-main. In that window choose UPPER field from the drop down menu ("off" does nothing) also in the drop down menu below choose your footage type: HDV. Alternatively H264 does a good job of deinterlacing (when checked) most of the time. This has solved my horizontal line problems. |
needs to stay interlaced
The problem with de-interlacing is that the end product needs to be 60i, otherwise the motion will be jittery. Can after effects take each i field and create a SD P frame from it?
