No video playback in Color at DVinfo.net
Final Cut Suite
Old May 24th, 2007, 07:38 PM   #1
Hi all,
I cannot get Color to playback video. If I play a clip in the timeline, the video preview part of the Scopes window is all black, and the scopes are all just displaying the value of black.
I'm using Color on a MacBook, so it's using the Intel GMA card. I know that technically FCS2 doesn't want you to use Intel GMA cards (they are not technically supported), but FCP works fine with my Intel GMA. And if I go into the Secondaries room in Color, enable secondaries, and choose the Previews tab, then Color will display that preview in the Scopes window. But I cannot get normal playback to work, e.g. so I can use the Primary In room.
Has anyone experienced this problem, or know for sure if Color just plain will not work with Intel GMA?
Adam
Bourbon: It's hard being a small time gangster.
http://www.bourbonmovie.com
Adam Woodworth is offline   Reply With Quote
Old May 24th, 2007, 07:43 PM   #2
Apple's pretty clear that Color only works with certain graphics hardware. They have a second set of system reqs for Color that are outside of the FCS2 specs.
My Work: nateweaver.net
Old May 24th, 2007, 07:47 PM   #3
What's interesting is that when I render the video in Color so that the orange bar turns green above the timeline, and playback the resulting .mov file in QuickTime (outside of Color), it's still black.
Now I know that the Intel GMA supports GPU acceleration, it isn't a speed demon but it works. I wonder if Color is completely GPU accelerated and refuses to run GPU code on any video card that is less than the Color requirements...
Old May 24th, 2007, 07:59 PM   #4
Bingo.
In addition, it uses specific OpenGL features that only certain cards have...that's why they say only xxx and yyy cards will work.
Nate Weaver is offline   Reply
