1080i to SD progressive at DVinfo.net
Final Cut Suite
Old May 3rd, 2007, 08:12 AM   #1
Hi,
i'm figuring how to keep the best from a 1080i footage in a SD sequence. But i need your opinion, is it worth?
Here the procedure i tried:
importing HDV 1080i footage in FCP (in this example we are working in PAL
deinterlacing it (you still have 1080 x 540 resolution)
put that deinterlaced file in a DV-PAL sequence.
Result?
The footage should be full SD progressive, because for every SD line there will be a line from the HDV single field (and resizing the HDV file at 0.5 X, you will have 540 full progressive lines (that means that there will be a small letterboxing, invisible on a TV set)
I tried it, and it seems to be better than shooting SD then deinterlacing it.
Do you agree?
Giovanni Speranza is offline   Reply With Quote
Old May 3rd, 2007, 08:34 AM   #2
Self comment:
i compared that to a simple "deinterlace" done on the HDV clip that is in a SD sequence. Exactly the same..
Old May 8th, 2007, 01:32 PM   #3
How did you deinterlace?
Scott
Scott Shama is offline   Reply With Quote
Old June 19th, 2007, 07:01 AM   #4
by retaining only one field
