M2v coversion - 2seconds per frame? at DVinfo.net
Final Cut Suite
Old April 9th, 2007, 03:46 PM   #1
I'm new to FCP and HD so hopefully there's something I don't know here -
Converting my HD footage, with very minor filtering, to SD m2v (for DVD) is taking a little over two seconds per frame, which is over a minute per second, an hour per minute - it would take 2 days non-stop to convert my video of one band's set at a club to DVD.
I'm using the lowest settings that produced decent quality (it's rendering now so I can't look it up) but this seems awfully slow.
The in-camera down-convert ( Canon XHA1 ) looked pitiful, but maybe there's something I'm missing here.
Any ideas, info?
Glenn French is offline   Reply With Quote
Old April 9th, 2007, 04:45 PM   #2
Just out of curiousity, what kind of Mac do you have?
John C. Chu is offline   Reply With Quote
Old April 9th, 2007, 06:10 PM   #3
It's a G5 dual processor 2.3Ghz, 2.5GB RAM
Old April 9th, 2007, 06:55 PM   #4
I think the issue you have is those filters---when you apply a filter to the whole movie, each frame has to be rendered...hence the long render times.
I have a 20 minutes sequence in HD from my HV20 and it looks like it will take 2.5 hours to convert it into SD DVD on Dual 2.0 G5 PowerMac with 2.5gigs of ram.
"Scotty, we need more power!"
Old April 9th, 2007, 11:14 PM   #5
The xha1 downconvert looks pitiful? That's a bummer. Hadn't heard this about downconverts from camera. I was hoping to start shooting hdv with my xha1 and downconvert out of camera to fcp. Was hoping to avoid rendering times and distribute in sd. Then if needed recapture for hd delivery.
Martin Kornfeld is offline   Reply With Quote
Old April 10th, 2007, 06:23 AM   #6
Maybe not -
I tried down-converting straight to a consumer DVD recorder and that looked good.
I'm still experimenting - there might be a combination of settings or something I'm missing.
GRF
Old April 10th, 2007, 06:34 AM   #7
I just shot a project with the A1 in HD, and down-converted to SD in-camera,
and the footage looked fantastic.
Old April 10th, 2007, 07:39 AM   #8
What settings did you use?
I have tried dozens more settings and all I get is 8-blocks - it all looks viewed through a grid. Unacceptable even for iPod.
Please, what capture/sequence settings? What I'm getting can't be right.
GRF
Old April 11th, 2007, 08:44 AM   #9
Really, is it a simple preset? No one could ever use what I'm getting here.
I'm wondering if something is wrong with the camera.
Old April 11th, 2007, 01:34 PM   #10
Hours more variations, the same 8 by 8 pixel blocks, no relief, no help.
Unusable $8000 setup.
I'm sure the answer is simple.
Old April 11th, 2007, 02:55 PM   #11
Glenn,
Try dropping your HD timeline into an SD timeline and export from there.
Writer-Director-DOP
www.liamhall.net
Liam Hall is offline   Reply
