Audio Editing Problem Almost Solved, Help at DVinfo.net
Final Cut Suite
Old March 15th, 2007, 02:54 PM   #1
So I am one step closer to figuring out the mystery behind why there is "no" audio in the quicktime file that I imported into FCP from MPEGStreamclip. Actually, the audio is there but much later in the clip. The full audio was captured by it is much shorter than the video clip. It is not synced up at all. Can't figure this out. Where in the capture work-flow of DVHSCap to MPEG Streamclip to FCP did my audio get out of sync? I used the Uncompressed audio in MPEGStreamclip with AIC codec. How do I sync the audio back up so I can use the footage to edit in FCP?
Oh so close it hurts.
Sharon Pieczenik is offline   Reply With Quote
Old March 16th, 2007, 10:19 AM   #2
CORRECTION!!! Not all of the audio was captured. It started a lot later than the video and then it stopped capturing when the video stopped capturing. Any thoughts?
