same timeline settings as footage, but no real time and exported files bigger?? at DVinfo.net
Final Cut Suite
Old March 11th, 2007, 08:57 PM   #1
I m editing 25P Pal dv footage, i ve set my timeline settings to match my footage, but i have this "orange bar" instead of green, and when i try to export my edit ( with same settings again ) my files are 10 times bigger that they should be, like 5 gigas for 4 minutes... of dv.
anyone can help me?
Jeremie Galan is offline   Reply With Quote
Old March 12th, 2007, 03:52 AM   #2
Jeremie,
Check your RT setting is set to "safe". Orange is for unlimited.
Double check your timeline settings are DV-PAL compressor.
How did you export? You may have used the wrong export codec.
Liam.
Writer-Director-DOP
www.liamhall.net
Old March 12th, 2007, 05:18 AM   #3
well it seems that my timeline was in uncompressed 8 bits :)
I changed it to DV pal, realtime playback now ;) but let's imagine i just want to export an edited rush without any compression but with the size of dv format, do i have to choose DV pal compression in the export setting too?
it seems to add more compression to the already dv pal of my timeline, and when i choose uncompressed 8 bits the files are way too big...so to sumarize : How to export dv footage edited from fcp without any other compression and in the size of normal dv footage?
sorry for the crappy english
Old March 12th, 2007, 05:31 AM   #4
Jeremie,
Don't worry about the crappy English, most people here in England can't speak it, let alone write it.
To export a DV-PAL movie from a DV-PAL timeline simply go;
File>Export>Quicktime Movie...
Use 'Current settings'
Don't check 'Recompress all frames'.
Do check "Make self contained movie'.
Hope that helps.
Liam.
Writer-Director-DOP
www.liamhall.net
Liam Hall is offline   Reply
