Grainy video at DVinfo.net
Final Cut Suite
Old April 19th, 2003, 11:59 AM   #1
Grainy video
I was given some 'grainy'raw footage which I want to clear up. I have both FCP3 and Premiere. Any suggestions?
KP
K. Penewit is offline   Reply With Quote
Old April 19th, 2003, 03:29 PM   #2
Warden
What is it shot on DV, analog?
Jeff Donald
Carpe Diem
Old April 19th, 2003, 03:50 PM   #3
Canon GL-2
It was shot with a Canon Gl-2
Old April 20th, 2003, 07:04 AM   #4
Warden
In FCP, go to Effects>Video Filters>Image Control. I've had limited success working with brightness and contrast, as well as adjusting levels. I've also used Gaussian Blur with limited success.. The 3 way Color Corrector may also be of limited use. Small adjustments have the best effect. Large dramatic changes often make the images unusable. As you can probably tell, fixing grainy images is not easy and no one filter makes the image perfect. Experimentation may give you an image that proves acceptable.
Jeff Donald
Carpe Diem
Old April 20th, 2003, 07:20 AM   #5
Thanks Jeff
Old April 20th, 2003, 08:04 AM   #6
I am not familiar with FCP or Premiere, but maybe look for "frame averaging". If there is not too much (fast) motion in the image you can significantly reduce noise. Even better, and used in some pro cams and medical (ultrasound) and Defence equips is motion adaptive averaging. An example (for a still image) of this powerfull temporal averaging technique can be found here http://www.nlectc.org/assistance/frameaveraging.html
Andre De Clercq is offline   Reply With Quote
Old April 23rd, 2003, 06:14 PM   #7
Guest
Posts: n/a
There's a plugin called Grain Surgery that is supposed to do wonders. I've never used it. There's a downloadable demo. It's 400 bucks, though. It plugs into After Effects, Final Cut, Commotion, and Avid X DV. You could call around to effects houses in your area and see if you could rent time or pay for their services. Might be cheaper than buying the plugin.
