Audio Track Dropout in FCE at DVinfo.net
Final Cut Suite
Old February 10th, 2007, 04:08 PM   #1
Anyone ever had this happen, or know why it would happen?
I was editing in FCE 2.0 and had completed a sequence with 8 audio tracks. At one point in the sequence each track is in heavy use (2 dialog channels as stereo pairs, room tone as a stereo pair, and music as a stereo pair). The problem came when it was time to export. I exported using the Quicktime File option (not quicktime conversion) and then watched the file to ensure that everything was OK. Every time I played the file, no matter that it played fine as a sequence, the music (tracks a7 & a8) would drop out when the room tone (tracks a5 & a6) were introduced. Earlier in the sequence I had used all eight tracks, but not as heavily. There were significant breaks in tracks, and all 8 tracks exported fine.
I ended up having to clip the room tone early, move the music up to A5 & A6, and then it exported fine.
Anybody have any clues? I thought that FCE could handle well over 8 tracks (I thought it was 99)? Or rather, FCE handled it fine until I was exporting.
Thanks for the help,
Kevin
"... the drama is on your doorstep..." - John Grierson
www.grvideo.net
Kevin Randolph is offline   Reply With Quote
Old February 11th, 2007, 10:36 PM   #2
Did you Mixdown the Audio before export? (Select all in the timeline then Sequence>Render Only>Mixdown)
And was everything rendered first?
Victor Kellar is offline   Reply With Quote
Old February 12th, 2007, 10:06 AM   #3
Yes, all was rendered and I did the audio mixdown. Any other thoughts?
www.grvideo.net
