How to rip DVD content into Final Cut Pro at DVinfo.net
Final Cut Suite
Old February 5th, 2007, 03:53 PM   #1
Hi, I'm ripping content off DVD using Mpeg Streamclip. I'm using the "export to DV" setting. The picture imports into FCP without any need for rendering (I'm using the DV25 sequence preset), however the audio needs to be rendered.
Why does the audio need rendering? Is there a sequence setting to avoid this?
Scott Jaco is offline   Reply With Quote
Old February 6th, 2007, 07:21 AM   #2
DV streams are not a natively supported editing format in FCP, instead you should Export to Quicktime Movie and choose DV as the codec there
Andy Mees is offline   Reply With Quote
Old February 6th, 2007, 08:49 AM   #3
That worked! Thanks.
