Native format? at DVinfo.net
Final Cut Suite
Old December 13th, 2006, 12:43 AM   #1
Native format?
Hi,
It's my first time capturing and editing footage I shot on the hd100-u. WE shot at 720 p24 in the letterbox frame ratio. I have followed the suggestions in teh topmost sticky about my A?V settings (ie HDV, 23.98 fps) etc. And all seems good, but when I drag a recently captured clip onto the timeline it needs rendering. Is this just the case because its HDV, or do I still have some setting wrong? Thanks,
Michael
Michael Bodel is offline   Reply With Quote
Old December 13th, 2006, 04:23 AM   #2
It shouldnt need rendering. What computer and editing software are you using?
Peter Ford is offline   Reply With Quote
Old December 14th, 2006, 12:17 AM   #3
final cut 5.1.2. any ideas?
Old December 14th, 2006, 09:37 AM   #4
What I do to make sure it matches up is scroll to the right in your clip bin and make sure every detail matches up between your sequence and your clip.
Northweststockfootage.com
Shooting 100% HD
Washington, Oregon, and Soon British Columbia
Mack Fisher is offline   Reply With Quote
Old December 14th, 2006, 04:45 PM   #5
In FCP, if you created your sequence before doing the easy setup, you may need to create a new sequence with the correct settings. As stated above, just look at the sequence settings (Command 0) and make sure they match a clip that is captured in the bin.
Steve Benner is offline   Reply
