merge clips...Is it possible? at DVinfo.net
Final Cut Suite
Old November 19th, 2006, 10:51 AM   #1
I am new to fcp 5 and with lots of xp with ppro2.0. Back in my ppro2.0 days, merging clips was easy.
Not so in fcp...
I cannot merge two clips for the life of me. When ever I try to select "merge clips" it always unavailable. It is almost like the software doesnt even have the function.
I have tried everything!
What are the requirements in order to merge two or more clips?
I am editing hdv 24p from the jvc hd100. The reason I have to merge the clips is because fcp broke the capture up in to multiple files instead of one big file. Its a known problem with fcp and the jvc hd100.
Jonathan Nelson is offline   Reply With Quote
Old November 21st, 2006, 01:29 PM   #2
I guess it is not possible.
Old November 21st, 2006, 02:15 PM   #3
What does the function do?
Since FCP users are not familiar with the terminology, we don't know what you're asking.
Does it take two clips in the bin, "merge" them together so they are one, new clip? If so, FCP doesn't do that.
[edit: I just went searching in the FCP help file, and it explained everything. Merge Clips in FCP is for syncing video clips to audio clips for double system productions. not for joining multiple video clips]
My Work: nateweaver.net
Old November 21st, 2006, 02:30 PM   #4
Thanks for the clarification. What I wanted to do is join mutliple clips together so that I can use them as one angle in a multiclip.
Right now, the only solution I have found was just exporting a new file. Sounds like there should be a way around this.
Old November 21st, 2006, 02:44 PM   #5
Johnathan,
Try looking into nesting the sequence in FCP. FCP treats sequences like clips. Don't if this is what your looking to do? but I hope it helps.
Carlos Viteri - www.clvideo.com
Where Vision Meets Video
Carlos Viteri is offline   Reply With Quote
Old November 21st, 2006, 02:47 PM   #6
Originally Posted by Carlos Viteri
Johnathan,
I will look into this. Nested sequences would do the trick if they can be used in a multiclip.
Thanks for the tip.
