Editing App to Edit 5 fps Movies? at DVinfo.net
Final Cut Suite
Old November 13th, 2006, 08:15 AM   #1
Is there any Mac editing program that can handle the editing of 5 fps movies? I've tried with FCP but it only seems to accept standard frame rates of 24 and 30 fps.
I'm editing videos captured with Snapz Pro (screen capture software for Mac) recording at 5 fps for some online video tutorials. There seems nothing available to edit movies of slower frame rates.
Ian Holb is offline   Reply With Quote
Old November 14th, 2006, 02:19 PM   #2
Have you tried to set the framerate to 5 fps in the sequence settings?
Gunleik
Red? Sure!
Gunleik Groven is offline   Reply With Quote
Old November 14th, 2006, 03:22 PM   #3
Images: 1
Gunleik
It seems you can't. If you use the advanced tab of the video compressor, you can set the framerate to 'custom' then type in '5' for a value. But as soon as you exit the advanced tab, back to FCP sequence setup, it gives you a message that the framerate change was ignored. Kind of a bummer cause I thought I had found an answer for Ian, but no such luck.
-gb-
Old November 15th, 2006, 04:17 PM   #4
I can't recall if older versions of FCP allowed custom frame rates, but I believe it may have. Unfortunately, none of my Macs are able to run OS9 so I can't test older FCP versions.
Old November 16th, 2006, 03:40 PM   #5
http://www.proapptips.com/proapptips...Tutorials.html
Watch Shane's videos, the one about editing non-standard codecs. It should get you what you need in FCP.
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply With Quote
Old November 17th, 2006, 01:21 PM   #6
The slowest frame rate FCP seems to accept is 10fps. Good enough for me! Thanks for the link.
