Downconverting a HDV Timeline in FCP5... - Page 2 at DVinfo.net
Final Cut Suite
Old March 29th, 2007, 06:31 AM   #16
no uncompressed 8-bit standard def anamorphic
Quoting Nigel:
"You have your HDV timeline, hit Command A to select all the timeline, then hit Command C to copy, then open a new sequence (make sure the 'warn for new presets when opening new sequence' is turned on in your settings) and set it up as an uncompressed 8-bit standard def anamorphic one."
I've tried Nigel's solution but my FCP 5 doesn't have uncompressed 8-bit standard def with anamorphic as an option. Just without anamorphic. Am I missing something?
Last edited by Martin Kornfeld; March 29th, 2007 at 09:46 AM. Reason: clarification
Martin Kornfeld is offline   Reply
