Aspect ratio change from Motion to FCP at DVinfo.net
Final Cut Suite
Old November 1st, 2006, 11:02 AM   #1
I exported my 16:9 clip from FCP to motion, added my text & effects, and when I get back to FCP the clip I edited in motion has switch to 4:3. The canvas in motion is 16:9..Stumped...
Any good microphones out there for a G5 for voiceovers???
Thanks for the help!!
Kipp Felice is offline   Reply With Quote
Old November 1st, 2006, 11:08 PM   #2
I think this should fix the problem:
If you select your motion project in the browser then scroll over until you get to the anamorphic column. Put a checkmark there and it should work, you may need to re-edit it back to the timeline.
http://creativemac.com/articles/view...e.jsp?id=61800
this should help out as well
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply With Quote
Old November 2nd, 2006, 07:33 AM   #3
Nate, thanks for the help that turned out to be an easy fix, thanks again...
