Keyframing speed at DVinfo.net
Final Cut Suite
Old March 18th, 2003, 03:49 AM   #1
Keyframing speed
Is there any way to Key frame the speed controls in Final Cut Express?
I would like a clip to start at normal speed and then gradually slow down over time. I can't see anything in the manual about how to do this. All I've thought of is cutting the clip down into lots of bits and then altering the speed individually and incrementally to each bit.
Thanks in advance for any suggestions...
Justin Morgan is offline   Reply With Quote
Old March 18th, 2003, 10:03 AM   #2
Joes Filters plug ins for FCP has a Time bender effct which lets you do this by setting keyframes to a single clip controlling the speed.Actually you can get this plug in for free by filling out a FCP survey.
www.joesfilters.com.
Matt Stahley is offline   Reply With Quote
Old March 18th, 2003, 10:54 AM   #3
Retired DV Info Net Almunus
I second Matt's recommendation for Joe's Filters. I think that this toolkit is the best value for FCP plug-ins today.
The "free" alternative would be to use the razor tool to slice the clip into small chunks and set the speed for each chunk. It would not produce as smooth of a result as Joe's Time Bender, nor would it be as flexible.
Old March 18th, 2003, 11:16 AM   #4
Thanks - will Joe's Filters work in Final Cut EXPRESS?
Old March 19th, 2003, 10:21 PM   #5
Warden
FX Script and AE plugins will not work in FCX. I've not spent much time with FCX, but i can't think of a way to make the speed effect work the way you want. You thought on cutting up clips will work, but is time consuming
Jeff Donald
Carpe Diem
Old March 19th, 2003, 11:05 PM   #6
Joe's Filters are built with FXScript, not AfterEffects scripting. So they will work with Final Cut Express. See the Joe's Filters site for full information.
Readers should also note that Apple is apparently giving away copies of Joe's Time Bender, the filter discussed here, for free in exchange for completing a Final Cut Pro user survey. This is probably only applicable for FCP users, not FCX users.
Old March 20th, 2003, 09:11 PM   #7
Time Bender and FCE
Unfortunately Time Bender does not currently work with FCE because the plugin needs keyframes to create the time remapping effect. I'm working on a solution, but my plate's a bit full right now.
Thanks for all the great comments about the filters,
Joe Maller
www.joesfilters.com
Joe's Filters for Final Cut Pro and Final Cut Express
Joe Maller is offline   Reply With Quote
Old March 21st, 2003, 06:25 AM   #8
Warden
Sorry, I misstated the reason for Time Bender not working. FCX does not contain scripting, like FCP does. However, filter created with FX scripting do work in FCX. AE plugins do not work in FCX. The issue with Time Bender not working is due to the way FCX handles keyframes.
Jeff Donald
Carpe Diem
Old March 21st, 2003, 06:51 AM   #9
Shame it doesn't work with FCE - after I filled in that pesky questionnaire too :(
