iMac whith fcp at DVinfo.net
Final Cut Suite
Old October 24th, 2006, 07:51 PM   #1
iMac whith fcp
Hello folks, any one using imac with FCP expres or FCP pro.
I need your best opinions.
Thanks in advance.......Franklin
www.franklinbencosme.com
Franklin Bencosme is offline   Reply With Quote
Old October 24th, 2006, 08:26 PM   #2
I use an Intel iMac and FCP 5.1.2 and it rocks. I maxed the ram and upped the hard drive and graphics card. Great editing machine, as good or better than my dual G5 at work.
www.CodemanStudios.com
Cody Lucido is offline   Reply With Quote
Old October 25th, 2006, 01:54 PM   #3
Hi Franklin,
I use a 17" G5 iMac with FCP 5 for onsite same-day edits. Works great. I have it hooked up to an additional monitor in the office for DVD authoring and burning along side a dual G5 tower. You can span two monitors with an iMac with this:
http://www.rutemoeller.com/mp/ibook/ibook_e.html
Joel Peregrine is offline   Reply With Quote
Old October 25th, 2006, 06:32 PM   #4
Thanks For The Information.
Franklin........
Old October 26th, 2006, 01:40 PM   #5
Originally Posted by Joel Peregrine
Hi Franklin,
Don't the iMac come with a mini-DVI connection on the back. All you would need is a mini-DVI to standard DVI cable to connect the 2nd monitor. Though I've only ever seen the newer intel iMacs.
Glen Elliott
Cord 3 Films
Glen Elliott is offline   Reply With Quote
Old October 26th, 2006, 09:23 PM   #6
All the flat panel iMacs come with the mini-DVI IIRC but only the Intel ones allowed extended desktop without any kind of hack. The G5's only allowed mirrored desktops so you had to do the above mentioned workaround.
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply
