Problem with audio when editing to tape in FCP at DVinfo.net
Final Cut Suite
Old October 24th, 2006, 06:22 AM   #1
I am editing a sequence to tape with 8 audio tracks but after the 1rst minute, there is a problem with the audio: the clips are played in a random order then nothing ! The sequence I am outputing has another sequence nested in it. This is not the 1rst time this happens
I trashed the prefs and the render folder, but it did not help. Everytime the problem happens at the very time timecode. Any idea ?
Steven Nichols is offline   Reply With Quote
Old October 24th, 2006, 08:01 AM   #2
Try doing a Sequence - Mixdown Audio before you go to tape. I've heard that doing a mixdown will correct some of the those problems. Hope that helps.
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply With Quote
Old October 24th, 2006, 11:22 AM   #3
OK thanks, it worked. I thought I already rendered the audio, but the mixdown did the trick ;)
