Anyway to create 480p from 480i with FCP 5.1.2 at DVinfo.net
Final Cut Suite
Old October 20th, 2006, 03:10 PM   #1
The camcorder I have (GS70) shoots 480i and I'd like to create 480p for import into DVDSP4..........Can that be done using FCP 5.1.2?
Would someone turn on the lights!?
Doug Fearman is offline   Reply With Quote
Old October 20th, 2006, 05:59 PM   #2
Which kind of 480p? 24 or 30? It's simply a matter of deinterlacing the footage to make 480p30. The deinterlacer in FCP is not regarded as the best. I convert everything I shoot to 480p30 using either Natress Film Effects filters or a free filter called Quick.Look
Now 24p is a different story since you are actually removing frames, deinterlacing frames, and blending frames all at the same time. To achieve the proper look I would highly recomend Nattress Film Effects.
Dave Perry Cinematographer LLC
Director of Photography • Editor • Digital Film Production • 540.915.2752 • daveperry.net
Dave Perry is offline   Reply With Quote
Old October 20th, 2006, 07:30 PM   #3
Dave,
Thank you very much for your reply. I do have Nattress Film effects. It's just that when I add the G-film@24p or 30p to the clip in the FCP timeline and export as an mpeg-2 file via the apple compressor; the track always show up as a 480i in DVDSP-4 with no options for converting to 480p.
p.s. Thanks for the information on quick look. I'll give it a try.
Old October 21st, 2006, 07:48 AM   #4
Well, actually I should clarify. For 24p, you need to work in a 24p timeline. You can't just take the 480i footage that you've captured and put a filter on it to make it 24p in a 29.97 timeline. Adding the G-film@24p filter in a 29.97 timeline just gives you 3 frames of deinterlaced plus 2 interlaced so it'll fit the timeline. If you have a interlaced production monitor or even a TV set that you monitor FCD through, you'll see that when you go frame by frame through your footage, you have 3 frames that don't flicker then 2 that show the interlace flicker.
Compressor does not change frame rates for you. It just converts that footage to a new format at the same frame rate of the source footage. There are options for deinterlacing though.
Go To this page at Nattress.com to find out how to use the stamdards conversion filter to make 24p footage in a 24p timeline. Scroll down to the "Standards Conversion - Tutorial Movies".
Old October 21st, 2006, 07:59 AM   #5
Thanks for all your help Dave.
Old October 21st, 2006, 08:25 AM   #6
No problem. Glad to do it. I'm just passing on what I learned right here on dvinfo.net.
Old October 21st, 2006, 08:50 AM   #7
That's what the problem was......I have Film Effects but I don't have Standards Conversion. I downloaded the demo and created a clip to burn to DVD then it's over to my daughters' house to check it out on her HD set.
Maybe I'll ask for the Standards Coversions Software for Christmas.............
Thanks again Dave.
God Bless,
Doug
