No sound in NLE! at DVinfo.net
Final Cut Suite
Old October 13th, 2006, 08:16 PM   #1
No sound in NLE!
I can hear the sound of my footage (shootng 720/24p) on the speaker monitor, but not when I go to FCP, my A/V settings are on 'default' for audio, when I change it to 'built-in' it still doesn't do anything. Any ideas? Thanks.
Hayk Paul is offline   Reply With Quote
Old October 14th, 2006, 02:32 AM   #2
if you're changing it to built in audio at the upper toolbar under view, then make sure under audio video settings it is on built in audio as well. Or firewire/dv, depending on your desired output, sometimes audio video settings is setup differently then what the toolbar shows. hope this helps.
Eric Dyer is offline   Reply
