Interlacing lines at DVinfo.net
Final Cut Suite
Old October 11th, 2006, 12:41 PM   #1
Interlacing lines
Hi all,
I'm using a Canon Optura 20 camcorder to film some special features for my short film. I captured the footage just fine. In the preview window it looks great. However when I add my in and out points to the footage and add it to the sequence (by the way I'm using FCP 5.0.4), I get MAJOR interlacing lines. Check out this screen grab of what I'm talking about.
I'm pretty new to FCP so I have no idea what's going on. Any help on this?
Screen Grab
Adam Rench is offline   Reply With Quote
Old October 11th, 2006, 02:20 PM   #2
I guess you're monitoring on a computer monitor?
In case, don't worry.
Do a test-out to DVD and check the result on a TV. You'll probably be fine.
Gunleik
Red? Sure!
Gunleik Groven is offline   Reply With Quote
Old October 11th, 2006, 03:19 PM   #3
Is your canvas set to 100% zoom? That will show you the interlacing lines but again you should be fine that just happens when viewing interlaced footage on your progressive computer screen. You can play the video out through your camera to a TV to check it there.
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply With Quote
Old October 11th, 2006, 03:24 PM   #4
Originally Posted by Adam Rench
Hi all,
Screen Grab
Is your sequence set to DV-NTSC?
William Hohauser is offline   Reply
