Disabling Start/stop detection during Capture Now at DVinfo.net
Final Cut Suite
Old October 2nd, 2006, 04:58 PM   #1
I want to capture entire tapes, but when I do so it automatically creates new clips on each start/stop point, which sounds great, except that there's a 4 second gap at the beginning of each take. I know I should have done pre-roll, but in some cases I didn't and I don't want to lose the beginning of so many takes.
Any way to disable this function, capture the tape completely, then create subclips?
Craig Packard is offline   Reply With Quote
Old October 4th, 2006, 04:18 AM   #2
Craig:
Read through this thread to see how some people are dealing with this problem.
http://www.dvinfo.net/conf/showthrea...t=75138&page=4
good luck
Scott Tebeau is offline   Reply With Quote
Old October 4th, 2006, 04:44 AM   #3
Images: 1
In Audio/Video setup, go to capture preferences. Go to the 'On Timecode Break' and you have 3 choices. It defaults to make new clip. You should set it to 'warn after capture'.
Hopefully this will eliminate the issue.
-gb
Old October 4th, 2006, 03:13 PM   #4
Thanks for the suggestions
I did find that suggestion soon after posting, and it seems to have worked pretty well. I did the HDV Firewire NDF duplication and changed the pre and post roll to 1 second. I have had a couple captures interrupted, but I don't think it has been that many and nothing crucial so far. Fingers crossed...
I am surprised that there appears to be no way to change the default setting so you could capture the entire tape. I understand this used to be the way DV footage was handled. Maybe that was only with cameras without timecode?
