HDCAM in Final Cut Pro 5 at DVinfo.net
Final Cut Suite
Old September 14th, 2006, 09:14 AM   #1
Hi,
I have Final Cut 5.0.2 and will be shooting an upcoming project in Sony HDCAM.
1. What settings/software do I need to capture HDCAM in Final Cut?
2. I need to get and HD-SDI card. Is AJA or Blackmagic DeckLink a better choice. The DeckLink is a little cheaper, but is the quality the same?
Jeff
Jeff Kastner is offline   Reply With Quote
Old September 14th, 2006, 09:56 AM   #2
There's quite a few ways you can do this, depending on end quality you need.
1-The more difficult way is to ingest as something other than uncompressed for ease of edit, then edit, then re-ingest HDCAM at the end uncompressed for the best quality. You need a fast drive setup for this
2-You can bring in as DVCPRO HD, edit full size full res, and then output again that way. You still need a better drive situation than DV, but data rate is only 14MB/sec. This is a quality compromise, but one that most people would never be aware of.
Decklink cards have the same quality as a Kona, just less flexibility and features. The Kona control panel in particular allows for a lot of options.
My Work: nateweaver.net
Old September 14th, 2006, 10:44 AM   #3
Thanks Nate!
I was planning to shoot with Sony HDW-730s, but it's not set in stone. If I'm going to capture as DVCPro HD anyway, would it be just as good to shoot with a Panasonic AJ-HDX400?
