FCP out to the web at DVinfo.net
Final Cut Suite
Old August 23rd, 2006, 05:48 PM   #1
FCP out to the web
what is the best way to compress a 25 min. short te send over the internet.
please help.
Manny Rodriguez
Manny Rodriguez is offline   Reply With Quote
Old August 23rd, 2006, 08:29 PM   #2
compressor. part of FCP
Richard D Miller is offline   Reply With Quote
Old August 23rd, 2006, 08:48 PM   #3
I've been trying to do so with compressor but the file is still to big, what setting should I use?
Manny Rodriguez
Old August 24th, 2006, 05:17 AM   #4
There a many posts on this topic. You seem to have a size in mind as you say some are too big. You have 25 minutes of video. You know the maximum size you will tolerate. Do the math. Compressor lets you set the number of Kbitspersecond or choose a preset for several canned rates. The smaller you make the file, the more quality you lose. If you don't like the quality, then your plan to "send it out over the internet" is flawed.
Most video is put on a web server and is downloaded for viewing so the size of it doesn't really matter. It gets downloaded as it's watched. Agian, do some searching here.
Old August 24th, 2006, 12:25 PM   #5
Manny,
Progressive download is your best option with this video unless you can break it up into smaller clips. Unless you need to crop your output, you may just try control clicking on the sequence and using the QuickTime Coverter output option. Choose the Sorenson 3 codec if your viewers don't have the latest QT player. Choose the h.264 option for better quality at lower data rates if your viewer has QT 7. Experiement with a few options. Remember that they larger the file size, the longer the download for the viewer.
http://www.kenstone.net/fcp_homepage..._from_fcp.html
This link above takes you to a great step by step article on compression using QuickTime Pro. It may give you some ideas. I hope that helps,
CJ Rogers
Cale Rogers is offline   Reply
