just got my macook bro but how can i check and make sure that its the right harddrive at DVinfo.net
Final Cut Suite
Old August 16th, 2006, 07:56 AM   #1
I just got my macbook pro 15" w/ 2gig RAM and 2.16ghz but i also got the 100gb 7200 rpm hard drive and i wanna make sure its actually that hard drive is there a way i can look it up? the info says its a 100gb ata or whatever doesnt have the speed...HELP PLEASE! thanks
KEVIN
Kevin Odell is offline   Reply With Quote
Old August 16th, 2006, 08:02 AM   #2
Under the blue apple, select "about this mac." In the little window, select "more info..." and it will bring up another window. Under "hardware" select "Serial-ATA" and it will provide you with the model number of your HD. Do a google on the model number and you sould be set.
Hope this helps.
Tim
Tim Brown is offline   Reply
