PLEASE HELP - Capturing in Final Cut Pro at DVinfo.net
Final Cut Suite
Old August 7th, 2006, 06:15 PM   #1
I recently purchased a Lacie D2 250 GB Drive. Runs fine.
I have been working with a 200 GB Western Digital hard drive and Final Cut Pro 4.5 on my Mac OS X system. Everything has been working perfect.
For some reason though, when I go to set the scratch disks for the new drive, I start to play the footage through the log and capture window, and final cut locks up. I have to force quit the program. I re-open the program, set the drive to the Western digital drive, and everything captures fine.
I can even copy files (word documents, video clips) from the main drive onto the lacie drive and it starts to copy just fine.
I've spoken with Lacie and they say it's something to do with Final Cut. Why would it have something to do with Final Cut when it works fine with the Western Digital drive?
If anyone could provide some insight to this issue, I would so greatly appreciate it.
Josh Woll
Josh Woll is offline   Reply With Quote
Old August 7th, 2006, 09:45 PM   #2
I had a problem with a new Lacie Drive once - the problem was in my formatting. The OS Extended (Journaled) option made the Lacie unable to play back any files in FCE.
I was told this was the best formatting to use as a scratch disc but it just wouldn't work. I then reformatted as Mac OS Extended without Journaling and it worked fine.
Hope this helps
Daniel Stevenson is offline   Reply With Quote
Old August 7th, 2006, 10:57 PM   #3
Images: 1
Hope this helps
I've heard the same things. Turn off journaling for a video capture drive. I think the NTFS equivalent is called drive indexing, not 100% sure as I only saw the NTFS option once when I was setting up a WD 250GB drive on my HP system.
-gb-
Old August 8th, 2006, 07:37 AM   #4
~I then reformatted as Mac OS Extended without Journaling and it worked fine.~
If you could explain more about this feature, and how to do this? I do not know anything about Journaling at all.
Thanks for your help so far!
Old August 8th, 2006, 08:19 AM   #5
Josh: Tell me your LaCie drive is connected via FireWire (and NOT USB) please?
Martin at HeadSpin HD on Blu-ray
Martin Mayer is offline   Reply With Quote
Old August 8th, 2006, 11:14 AM   #6
Its in the "Disk Utility" feature of OS X. By default, most LaCie (or external drives, for that matter [for mac]) come pre-formatted as Mac OS Extended with Journaling DISABLED. Once in Disk Utility, select the drive from the left, and check the formatting listed at the bottom. If it says "(Journaled)" then use the button at the top of the window to disable journaling.
If this does not work, or if it does not correct the issue, you may need to backup all the data and re-format the drive as Mac OS Extended with Journaling disabled.
I use a LaCie BigDisk 500GB va FireWire 800 and haven't had any problems... plus its fast.....
Matt Crane is offline   Reply With Quote
Old August 8th, 2006, 01:55 PM   #7
I haven't used the USB, only tried 400/800 as the hook ups into the Mac.
I checked the Disk Utility and it did not have journaled next to the drive.
I went ahead and put the journaled feature on and it still did the same thing in FCP.
More specifically, I open the log and capture window. I hit play. The timecode goes for about 2 seconds and then stops, but the camera is still running. Then the bubble from hell pops up and locks final cut pro for good.
See, I just received the drive so I have no trouble re-formatting the drive to make it work. I'm suppose to be getting another one of the same drives, so then I can see if it's this drive specifically that is malfunctioning. It's on back-order though so it might be awhile.
Thanks again guys for your continued help on this issue.
Josh
Old August 8th, 2006, 08:42 PM   #8
what does the dialogue box that pops up say?
Old August 9th, 2006, 08:04 AM   #9
There is no dialogue box that pops up. I give FCP a couple of minutes to see if the bubble will dissappear, but then I go to force quit and FCP is not responding.
I mean, it has to be something with the drive because if I'm to reboot FCP right off the bat after that happens, switch the scratch disks to the already running western digital drive, open the log and capture window and FCP starts capturing perfectly fine.
It's really weird because I've worked with Lacie drives and they are supposed to be the best for Macs?
I'm going to see if I can try it on a different computer with somone who is running a different version of final cut as well today.
I'll keep you posted on how that goes.
Old August 9th, 2006, 08:29 AM   #10
Guest
Posts: n/a
Possible Solution / Temp Work Around
Josh,
I had a similar problem at the beginning of the year.
http://www.dvinfo.net/conf/showthread.php?t=53333
If you can't find a solution and/or need to do something right now, you may want to change set your scratch drive to the desktop, do your "log & capture" of your footage, then drag and drop your capture folder from the desktop over to the Lacie as you need to.
Old August 9th, 2006, 10:46 AM   #11
Just use one
drive...Are you daisy chained to your other drives? Try using just the LaCie. They can be goofy...but the 250's are pretty good. I have had occaisions where I have daisy chained to a Western and the LaCie (this was a 500gb) got fickle. Also your machine runs much faster if you are using one dedicated drive.
JH
Jack D. Hubbard is offline   Reply With Quote
Old August 9th, 2006, 10:54 AM   #12
Location: Bangkok, Thailand (work in US in the summers)
Dang...wish I knew that journaled thing earlier...just got a new drive and have a bunch of stuff on it already...looks like a late night copying stuff off and reformatting as it won't let me change the journaled mode without an erase...
Paul
Paul Cypert is offline   Reply With Quote
Old August 9th, 2006, 05:19 PM   #13
Well gentleman, I went over to a friends house and tried the drive on his G5 with the latest version of Final Cut 5.1 and it worked fine. He was hooked in with 400 firewire and we were able to capture just fine.
My version of final cut is 4.5 HD. I'm going to try and shut off my western digital and just use the Lacie, but it sucks having to do that. I'll see if it works. My only hunch, if that doesn't solve the issue, is the version I have of Final Cut does not seem to work with the drive I have purchased.
Thanks guys for all your help and input.
Josh
