Apple Loops lost ? at DVinfo.net
Final Cut Suite
Old August 6th, 2006, 03:03 PM   #1
Apple Loops lost ?
Hi
A question for you talented clever people out there. I recently had my mac returned with new mother board (under warranty-phew !) and all was as is apart from when I load soundtrack pro all my aple loops are now in red and cannot be loaded into soundtrack pro. Do I need to reload everything , or is there a simpler thing I can do. If I double click on loop I hear nothing, it doesnt play.
Thanks for any help
Dont blame the weather....improvise !
Andrew Paul is offline   Reply With Quote
Old August 6th, 2006, 03:38 PM   #2
Have you checked if your loops are still on the harddrive? They should be, I think from memory, under your system Library-Application Support-Soundtrack Pro.
Check that first, unless you loaded them somewhere else or moved them. If they are not there, they may have to be re-loaded.
Thx.
Kevin
Kevin Wild is offline   Reply With Quote
Old August 6th, 2006, 03:39 PM   #3
Hey Andrew, assuming that all your apple loops are still on your machine (which I don't see why they wouldn't be) all you have to do is in Soundtrack Pro open up the search tab which is right next to the browser by default, click the setup button when that little window opens hit the "+" button and select whichever hard drive has all your apple loops then hit the index now button which should re-connect all your loops.
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply
