Soundtrack Pro screws up audio sequence when gain is added at DVinfo.net
Final Cut Suite
Old August 3rd, 2006, 08:13 PM   #1
Can anyone explain why whenever I try to add gain in Soundtrack Pro, my audio goes out of sync exactly 1hr 42min into the sequence?
I'm sweetening the audio for a seminar and the first seminar worked perfectly, now this other seminar loses sync when I add gain.
I'm using a quicktime reference file off FCP 5.1 just like I used for the first seminar.
The audio sync is perfect until I add the gain!
Any help would be appreciated.
Scott
Scott Jaco is offline   Reply With Quote
Old August 4th, 2006, 03:59 AM   #2
I seem to have found a work around. I just exported the .wav audio files from FCP then made the same adjustments in Soundtrack Pro, then exported the file w/compressor. It seems to be in sync now.
Scott
