Problem pasting Illustrator path in after effects as a mask
I am working my way through The After Effects Bible and have come across a frustrating stumbling block. I am followingan excercise where an Illustrator path can be pasted directly into an after effects layer window and be used as a mask. The thing is after effects won't allow me to paste my illustrator path.
i know this is a pretty specific problem but does anyone have any idea why it won't let me? Is there a prference box I need to tick or something? Last edited by Daniel Stevenson; July 24th, 2006 at 07:22 AM. |
You need to have the layer window active (not the comp window - try double clicking on a layer to open the Layer Window) and have a mask selected in order for AE to know where to paste that path. Try creating a new mask, selecting all the points on the entire mask, then paste. The new values from the Illustrator path should overwrite the previous points, assuming you have a proper closed path in Illustrator.
Thanks scott but it still won't work
The layer window is open and selected (the layer is a solid) I selected the mask with the selection tool (black arrow) Copied my outlined letter from illustrator (I have tried with a bezier closed path too) tried to paste in layer window, but it won't - paste is greyed out in the edit menu too Anything else I can try? |
Sorry, there's a gotcha in there I forgot to mention (I actally didn't know about it until I read the AE Help file).
From the AE Help File: "To import an Adobe Illustrator path as a mask: In Adobe Illustrator, create your path, select all of the points along the path, and then choose Edit > Copy. In After Effects, open the Layer window for the layer into which you want to import the path. Choose Edit > Paste. Important: You must select the AICB option in the Files & Clipboard section of the Adobe Illustrator Preferences dialog box for this method to work." I guess when they say "Important", they're serious. Next time, I'll RTFM. BTW, I was using Illustrator CS and AE 6.5, if that makes any difference. It works like a charm, now. You don't even need to have a mask selected. As soon as you hit paste in the Layer Window, it creates a new mask in the right shape, all edit-able vector goodness. |
#5 |
Scott you're a champion - it worked! I think it would have been a while before i worked that one out. Thanks heaps.
