IDVD3 and artifacts at DVinfo.net
Final Cut Suite
Old June 15th, 2006, 04:33 AM   #1
IDVD3 and artifacts
I edited a peice 5 mins with final cut Express one, exported it as a Quicktime file to IDVD3 and burned it ,but it is terribly artifacty, square pixels etc, what is wrong does anyone know.
thanks
john
John Doran is offline   Reply With Quote
Old June 15th, 2006, 07:24 AM   #2
Did you do a quicktime movie or a quicktime file export? If it was a QT file export you really have to checck your settings. If it was a QT movie export then it should have been fine. If that's the case, I've had similar problems when trying to use any DVD's greater than 4x speed on my powermag G4.
Lorne Mathre is offline   Reply With Quote
Old June 15th, 2006, 09:08 AM   #3
b
thanks
it was a final cut movie, and it worked fine
j
