update project (4.5 to 5.04) / firewire causing strobing at DVinfo.net
Final Cut Suite
Old June 7th, 2006, 08:01 AM   #1
Hey everyone, i edited some HDV footage (captured as DV) on my powerbook with 4.5. I was planning to do grading/effects/de-interlacing on a much faster powermac G5. I transferred the entire project over to the tower via firewire. When i open the project in 5.04 on the G5 i select 'update project' (it can't be opened otherwise i assume?). When i do this all of the footage becomes choppy. It looks kind of like a slow frame rate, or some ugly strobe effect. I know it's not just a playback issue cause i exported a dv movie and the resulting file still had the ugly strobing.
Now the way i see it the problem can only be either:
A. the firewire transfer
or
B. the project update
anybody have any experience with this kind of issue?
Luca F Lucarini is offline   Reply With Quote
Old June 7th, 2006, 11:55 AM   #2
I've upgraded DVCPro PAL projects from 4.5 to 5.0 and lastly to 5.1 and migrated them between machines - all without the issues mentioned by you. Short of suggesting to re-render after migration, I can't think of any other solutions off-hand.
HTH,
Ron
Ronald P. Pfister
halimedia - digital solutions and services
www.halimedia.com
Ron Pfister is offline   Reply With Quote
Old June 7th, 2006, 03:09 PM   #3
If you still have access to the original project file on your original machine try exporting the sequences as XML and importing those into FCP 5.
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply
