#16 |
Thanks to Everyone, But....
It still does not work. I have FCP set to "All Frames" in external video. I have my PD-150 set to "off" for A/V-DV Out (as I imagine that should only be on when I am capturing from an analog source and using the PD150 as a throughport/ media-converter). The image/sound go from FCP to the PD150 fine. It appears perfect through the LCD and can be recorded onto a MiniDV tape just fine. But when I connect RCA cables from the PD150 to my VCR the VCR records no image. If I connect the RCA cables from my PD150 to my TV to see what's wrong (I have a 36in. flat screen Toshiba) the image is horribly distorted. It rolls and bends etc. The same thing occurred when I connected a Formac media converter in place of the PD150. At this point I'm willing to spend the money on a VCR with a fireware port but I don't know of any. Do any of them support device control?
Again, thanks so much for everything everyone. Erik |
#17 |
Retired DV Info Net Almunus
Sorry to hear you're still having trouble, Erik. It certainly confounds me.
Yes, JVC makes a couple of models of dual miniDV-VHS decks that feature Firewire. Here's the JVC-SR-VS30U at Zotz Digital, one of our sponsors. JVC also makes a slightly lower model, the JVC-SR-VS20U, which generally runs around $1,100. I don't know the price of the 30U. Give Zotz a call.
Lady X Films: A lady with a boring wardrobe...and a global mission. Hey, you don't have enough stuff! Buy with confidence from our sponsors. Hand-picked as the best in the business...Really! See some of my work one frame at a time: www.KenTanaka.com |
#18 |
Moderator
- Ok, so we know its' not FCP, the problem exists in outputting the DV signal from the PD-150. Getting closer,,, >>>>But when I connect RCA cables from the PD150 to my VCR the VCR records no image. - doh! >>>>If I connect the RCA cables from my PD150 to my TV to see what's wrong (I have a 36in. flat screen Toshiba) the image is horribly distorted. It rolls and bends etc. - here's yet another dumb question: exactly what output are you using from the PD-150? Exactly what type of input are you trying to feed this into? Ok, that was two dumb questions! >>>>The same thing occurred when I connected a Formac media converter in place of the PD150. - OK, so its not the PD-150 either. The problem exists at the input stage of your monitor. Please take the time to use a different monitor - any monitor to see and let us know what you see, ok? >>>>At this point I'm willing to spend the money on a VCR with a fireware port but I don't know of any. - sounds to me like you need to spend your money on either the right cables or a repair of the video input on your monitor? Erik, please keep us posted, - don
DONALD BERUBE - noisybrain. Productions, LLC Director Of Photography/ Producer/ Consultant http://noisybrain.com/donbio.html CREATE and NETWORK with http://www.bosfcpug.org and also http://fcpugnetwork.org |
#19 |
Hey Don,
1. I am using the RCA outputs on the PD150. 2. I am connecting those RCA cables to the RCA inputs on the front of my TV. I'll try to connect a different monitor and let you know. Erik |
#20 |
Moderator
ok cool, by the way - what is the model # of that deck you are using?
- don
#21 |
Half of it working
Well, the ability to capture from my VCR thru my PD150 and into FCP 3 works. I'll update everyone as soon as I get the output from FCP 3 thru my PD150 to my VCR working.
Back to work! |
#22 |
Warden
VCR do not always auto detect a signal going into the line (RCA Video IN connection). Newer VCR's may have a setting in the menu (you may have to get to the on screen menu via your remote control). Set your VCR to record via the line rather than the "F" connection (maybe be labeled as CABLE, AIR, TV in the menu).
Jeff
Jeff Donald Carpe Diem Search DVinfo.net for quick answers | Where to Buy? From the best in the business: DVinfo.net sponsors |
#23 |
Thanks everyone!!!
You were right Jeff, I had to set the VCR to LINE and there was nothing in the manual about it. Thanks again everyone.
Erik |
#24 |
Warden
Thanks for posting back and letting us know how it all worked out. It can really help other people.
