HC1 to FCP at DVinfo.net
Final Cut Suite
Old May 15th, 2006, 04:40 PM   #1
HC1 to FCP
Hi All,
Need a little help. I am taking an HD Tape to FCP5 in native HD Format using an HC1. Computer can control the camera, but can't see the picture.
I have the settings dialed into 10801 easy setup but for some reason cannot get the video. Wierd. Help!
JH
Jack D. Hubbard is offline   Reply With Quote
Old May 15th, 2006, 08:44 PM   #2
Settings
Current Audio Video Settings Are:
Sequence PRESET HDV -1080I60
Capture Preset - HDV
Device Control Present - Sony HDV Firewire
Video Playback AJA Kona 1080i20.97 8 Bit (1920 x 1080)
Audio Playback: Default
Old May 16th, 2006, 01:35 AM   #3
Jack: I have no problems with the same setup as you (using FCP 5.1), using the same Easy Setup (HDV 1080i). That said, it seems that the problem descibed by you happens quite frequently. I would try the following:
- Make sure the camera is not set to down-convert HDV to DV (i.e. i.Link Conv set to OFF in the Standard Set menu)
- Check this thread: http://www.dvinfo.net/conf/showthread.php?t=67158 (don't know first hand if this would help you)
HTH,
Ron
Ronald P. Pfister
halimedia - digital solutions and services
www.halimedia.com
Ron Pfister is offline   Reply With Quote
Old May 16th, 2006, 01:28 PM   #4
Yup, that's it.
The camera had to be on HDV instead of Auto which is also the setting for HDV/DV downconvert. Thanks. I guess this is the new version of kicking the plug. Thanks a million, Ron.
Regards,
Jack
