#16 | |
I guess if I'm going to clone a drive - it probably would clone the problem. My next step is a complete rebuild. If that doesn't work I may have a G5 for sale. |
#17 |
Craig, a few more words of advice (hopefully) before you embark on your rebuild:
- After backing up all essential files, insert your OS install CD and shut down - Disconnect any third-party USB and FireWire peripherals - Boot-up with the OS install CD, choose your language, then launch Disk Utilit from the Utilities menu - Re-format your drive, writing zeroes over it (Erase-tab). This is the ONLY way to get rid of bad blocks on ATA/S-ATA drives, since you can't do a software-based low-level format. The IDE will map the bad blocks out when completely re-writing the disk, which is what writing zeroes does. If you want a partition scheme with more than one partition, you need to use the Erase function first (w/ zeroes). Once complete, you can re-partition as needed in the Partition-tab. - Once done, re-boot and do all the resets (P-RAM, Open Firmware, PMU) as mentioned before. After this, there's absolutely nothing left on your machine from the previous installation. - Then install the OS Good luck! HTH, Ron |
#18 | |
#19 |
Craig, any news on your battle front?
#20 | |
The nightmare is over
Just when I was about to hang myself with a disk reformat and rebuild a member on another forum recommended I CREATE A NEW USER ACCOUNT (w/admin privilages of course). Final Cut launched first try under the new account. I'm stupefied. |
#21 | |
HTH, Ron |
#22 |
Craig: since you couldn't get rid of the problem in the original user account, you may not have deleted all the FCP-prefs. You may want to try again, deleting the following files in ~/Library/Preferences in your old user account: com.apple.FinalCutPro.plist and the folder 'Final Cut Pro User Data'. Warning: deleting the latter also rids you of all your custom settings you may have created!
#23 | |
This little program kills all Final Cut 5 prefs with one click. http://pistolerapost2.com/fcprescue/ FC is now running in my original user account. |
