How far can I scale from HDV to SD? at DVinfo.net
Final Cut Suite
Old April 30th, 2006, 12:44 AM   #1
Hello,
I'm somewhat new to this...
I have HDV footage of sea life (dolphins, whales, etc) which I would like a bit closer. End product is regular DV Widescreen. I know I can "zoom in" in Final Cut--but is there an exact scale setting that equals DV resolution? I'm working under the assumption that I can crop off HDV's "extra" pixels without harming those that remain.
I'm trying to see how far I can zoom in without losing resolution (in DV).
--Darin
Darin Boville is offline   Reply With Quote
Old May 2nd, 2006, 02:53 PM   #2
Drop your HD footage onto a normal SD timeline ("sequence") and you should get a 1:1 ratio. You can then move it around and get what you want in frame.
-Sam
Sam Sutch is offline   Reply With Quote
Old May 2nd, 2006, 03:19 PM   #3
In theory you should be able to zoom in as much as 200% and still get usable results, but in practice I've found 150% to be a more realistic limit.
Old May 2nd, 2006, 03:28 PM   #4
Kevin:
I've noticed that pulling in .m2t file into a SD time line, the zoom affect doesn't translate very well. When you use Cineform intermediate do you have better results ?
Chris J. Barcellos
Old May 2nd, 2006, 10:23 PM   #5
I use Canopus Edius for editing, so my choices are native M2T or the Canopus HQ codec. Either one seems to work okay for zooming within the range I mentioned earlier, but Edius requires a workaround for SD output from HDV which causes problems with the zooming effect.
