Adjusting all subtitles at DVinfo.net
Final Cut Suite
Old March 14th, 2006, 09:08 AM   #1
I've got a bunch of text clips (subtitles) overlying my video. It has been decided to change the font size on all of them. Is there anyway of doing this without manually changing each individual clip? Can I select them all somehow and apply the change to all of them at once?
Thanks.
Tim Gray is offline   Reply With Quote
Old March 14th, 2006, 06:33 PM   #2
I don't think this is possible. The controls tab features don't show up in the paste attributes dialog box, and that's the only way I've ever found to apply a change to multiple clips. It's possible that some kind of XML tool would do this. If you have a software budget, you could look at Traffic or XML Title Cleaner.
Zach Mull is offline   Reply With Quote
Old March 14th, 2006, 07:47 PM   #3
Crap. That is what I was afraid of. Thanks for the info.
Old March 14th, 2006, 08:41 PM   #4
paste attributes might work....wont do it universally but saves a lil on haveing to enter the number each time for each clip.
Kevin Calumpit is offline   Reply With Quote
Old March 14th, 2006, 09:23 PM   #5
If all your titles are on the same video track you might try using the motion tab to scale them. That way you can paste attributes. Good Luck.
Jason Varner is offline   Reply With Quote
Old January 19th, 2009, 05:44 PM   #6
Change a lot of subtitles in Final Cut Pro
Hi,
that is what I have found, got the same challenge. To change multiple subtitles. The limit of the video that it does not say if you can do this and having other media on the timeline than the subtitles.
Here is the link
Final Cut Studio Warp Speed Workflow #3: Changing the font of all titles at once at DVcreators.net
Hope that helps.
The fish is the last to know the water.
Pavel Tomanec is offline   Reply
