AIC and HDV
is the apple intermediate codec GOP based or frame based? and is it inferior to HDV? It's just that even though I have a relatively new powerbook, it takes a long time to render GOP based footage. Just wondering if people out there use AIC?
"eyes through a digital world" |
It is frame based and inferior to native HDV. I doubt rendering AIC material will be faster than HDV except for Print to Video.
Please keep in mind that English is not my native language. |
I disagree with Ben. Version 1.0 of AIC may have had some problems, but version 1.0.1 is in no way inferior.
AIC is considered a "lossless" codec. It is not uncompressed, but the idea is that no new artifacts will be introduced, and the original quality of mpeg2 will be maintained. Here's my proof: Right-click here to download a TIFF exported via Mpegstreamclip from the original captured m2t file. and then right-click here to download and compare this TIFF exported from Quicktime Player Pro of the AIC converted version (via Lumiere HD) of the same shot. I chose this frame because it gave the Mpeg encoder a workout with the bright flashes and the dark areas, and smoke causing banding with the 8-bit bit depth. Therefore I consider this a "worst case scenario." Also, AIC will render effects way faster.
Tim Dashwood |
Hey Tim nice shot of the soldiers, but unfortunately the second file can't be opened it says it's corrupted, the AIC shot.
BTW I'm going to use your reversal/filmvert this afternoon on a shoot, I'll let you know how it goes. Tim is it easier to render on AIC than HDV? Thanks
#5 | |||
Tim Dashwood |
#6 |
Tim,
Your screen grabs do a great job of show how well the AIC codec works. With tabbed browsing in Firefox, the files open with the QT browser plugin and you switch between tabs to see some very slight differences. I actually like the AIC shot better. It seems to be a slight bit darker which is how I tend to color correct any way.
Dave Perry Cinematographer LLC Director of Photography • Editor • Digital Film Production • 540.915.2752 • daveperry.net |
#7 |
I dropped the AIC frame on top of the original in difference mode and the result is here. While the 2nd image indicates that there are significant differences between the two, the first shows that they are for the most part visually imperceptable. The only place where they might be visible is in the coronas of the muzzle flashes - seems to be significant difference in the blue channel only.
I'd say it's an insignificant difference considering the performance trade-off, especially on a machine with a slower processor. |
#8 | |
I admit that if you're going to use an intermediate codec AIC makes more sense than DVCProHD. The thing I hate about AIC is the change in workflow when capturing.
#9 | |
Tim Dashwood |
#10 |
I've put together a difference-mode test here with a video clip:
http://www.divergentshadows.com/hdv/...nce_video.html The original test video appeared pure black, it took a fairly extreme application of a level filter to make the difference as visible as it is in the clip above. You can see that the I frames exhibit the least amount of change between the two, although I'd estimate that over half of the pixels in even the I frames are different. Either way, the differences are so minute that they are unlikely to cause any visible difference unless you plan on running through multiple generations of the conversion. The video went from 3.2 to 10.3 MB/second in the conversion to AIC - apparently this can vary though depending on detail, motion, etc in the original clip, and tops out at about 12MB/second for 1080 HDV. |
#11 |
Very interesting. Is it correct to say that your video displays differences from 0 to 5 on a 0-255 scale? That is, white is a difference of 5 between AIC and HDV for a given pixel? Blue would be 1 "unit" difference, basically a bit error caused by rounding?
The "black" frames appear to be I-frames because they're strictly 15 frames apart. There's one thing in your comparison which may be unfair to AIC: I'm pretty sure Quicktime player decompresses each HDV-frame to uncompressed before encoding it to AIC, in contrast to Final Cut Pro's AIC capture which has access to the raw HDV material. Can you try this again, but this time capture the same clip twice, once in HDV and once in AIC?
#12 | ||
#13 |
Ok I just ran the test again, this time capturing the same clip as HDV and AIC in order to (potentially) improve the AIC error rate by transcoding rather than re-compressing...and there is good news and bad news.
First, the good. Capturing HDV directly to AIC appears to be slightly better than re-encoding via QT pro. Using the same methodology as above I would say most of the 3-channel difference dropped off at 4/5 while the final remaining blue/red differences were gone by 9/10 - so this drops the (potentially) visible errors down to a max 1.5% difference from the original. So, technically it's a slightly better conversion, although neither one should result in any visible difference from the original. Unfortunately, there's still the bad news - perhaps it's only news to me. This was the first time I'd tried capturing to AIC, and I was surprised to find out it does not allow for device control - therefore you cannot log & capture nor can you batch capture. It works only in a "capture now" sort of mode where it starts playing the tape and captures continuously until you hit escape. It also fails to retain the timecode from the original tape, so you cannot batch capture later. To me this would essentially make it completely unacceptable for any serious project. Without the ability to batch capture later you cannot back up a project without backing up all the media, and you can't archive a project without archiving all of the media as well. Considering AIC takes 3-4x the disc space, backing up all of your source media is considerably more difficult. Am I missing something here???? Or is this really the way it goes? |
#14 |
I have a different workflow using AIC. I capture and edit in Native HDV using FCP 5.04. Then I render out a MASTER clip in AIC. As I understand it, FCP goes to 4:4:4 before rendering out. Using AIC, I figure this is a virtually lossless version of the HDV originals. If you render out to HDV it adds UGLY artifacts. I could go out to Uncompressed but it takes HUGE storage. That then goes out through my KONA LH card to whatever deck I need. If it's SD, the KONA will downconvert on the fly. I'm working on a big doc right now and will rent an HD deck for the deliverable MASTER tape version.
I see no need to go to AIC first, instead of editing native HDV. Even if you add Color correction, it goes 4:4:4 before the final render. There is a link on Apples webpage about editing native HDV and mentions this, it's a PDF file that has been referenced here before. I've ran some tests and checked the results using "difference" in AE and this is the best quality/lowest storage solution I've found. As mentioned, this version of AIC is WAY better than the first one! |
#15 |
Paul,
I think you're right, AIC is probably the best mastering format (vs either HDV or uncompressed, etc). I think any conversion/render in FCP is done in a 4:4:4 space so it's definitely not losing much quality - it should match my first test which involved conversion from HDV to AIC and still produced no visible artifacts. However, I think there are definitely arguments to be made for capturing to AIC - you get smoother playback/scrubbing/shuttling & more realtime effects/higher quality realtime previews vs. native HDV. For some people the tradeoff in workflow speed vs. disc space is probably worth it, especially if disc space isn't an issue or if working on a slower machine (a powerbook for instance). However, the timecode and capture issues pretty much make it a useless option for any serious project, at least until cheap blu-ray burners become available for archiving! |
