Problem with Capturing, bad tape? at DVinfo.net
Final Cut Suite
Old February 20th, 2006, 05:48 PM   #1
We filmed a wedding this weekend with an XL2 and an XL1. No problems. However, today when we tried to dump our footage into final cut pro, we get this message after about 5 seconds of capture:
http://www.stinky.rednek.net/images/problem.png
We've tried capturing using the XL2 and a tape from both the XL1 and the XL2, and we've tried capturing using the XL1 using a tape from both the XL1 and the XL2, and I keep getting the same thing. I've restarted our powermac and everything.
Suggestions? Please don't tell me our tapes are screwed up.
Brian Farris is offline   Reply With Quote
Old February 21st, 2006, 09:25 AM   #2
Ah! I had capture mode set to PAL instead of NTSC! Silly me. What a noobish mistake to make. I'll make a mental note of that.
*For the search engines*
Capture encountered a problem reading the data on your source tape. This could be due to a problem with the tape. Capture has been aborted and your clip has been saved.
*End search engine stuff*
