capturing and editing 24p at DVinfo.net
Final Cut Suite
Old February 20th, 2006, 04:28 PM   #1
Hello all,
I own an XL2 and I edit with Final Cut Pro 5. My first question is...does it actually shoot in 24 fps or 23.98fps? When I set my sequence presets I'm selecting "DV NTSC 48 KHz Anamorphic" and I then select edit and change the frame rate to 23.98fps. Which is correct? Secondly, in my capture presets I using "Advanced(2:3:3:2) Pulldown" and I'm also selecting edit and changing the frame rate to 23.98fps. Before, I always kept it at 29.97fps without really knowing to change it. Which is correct? And lastly, in the Device Control Presets I'm using " Firewire NTSC Advanced" and I'm also changing the frame rate to 23.98fps. Is this correct or should it stay at 29.97fps, because what I'm noticing with these new settings is the motion isn't really as smooth.
Thanks for your help,
Reggie
Reggie Moser is offline   Reply With Quote
Old February 22nd, 2006, 10:07 PM   #2
There are a lot of posts here concerning this type of situation. The camera records 24p to 60i tape so everything but the sequence should be set to 60i. Chezch 2332 pulldown and your footage should drop nicely into a 23.98 timeline. Good Luck, Jason.
Jason Varner is offline   Reply With Quote
Old February 23rd, 2006, 01:10 PM   #3
Thanks Jason, I'll definitely go with your advice which is what I was doing before. You've been a lot of help.
