keyframes at DVinfo.net
Final Cut Suite
Old February 6th, 2006, 10:25 PM   #1
keyframes
How in heaven's do you copy a key frame motions to another clip in finalcut?
Dante Waters is offline   Reply With Quote
Old February 7th, 2006, 12:44 AM   #2
Select the clip in the timeline that you want to copy from. Now select Edit--Copy or CMD+C.
Right-click or Control-click the clip that you want to copy the attributes to and select "Paste Attributes" from the contextual menu that will pop up.
Now you can select which attributes to paste and whether to scale the keyframes to fit the duration of the new clip.
Tim Dashwood
Old February 7th, 2006, 01:40 AM   #3
at last...
Thanks you sir... I actually went ahead and did the titles in motion
rather than individually in photoshop so I got them to start at the right points
and end at the right points.
