Final Cut Pro troubles - Page 2 at DVinfo.net
Final Cut Suite
Old May 14th, 2006, 05:40 PM   #16
Images: 1
Originally Posted by Janete Taylor
My trash is empty trust me... I have tried everything that I know before I came and posted the help...
What I posted has nothing to do with dragging files into, or emptying the trash. It's handled within FCP. Give that method a try and see how much space you can free up.
-gb-
Old May 14th, 2006, 06:29 PM   #17
If you still have the project file you can select all your media that you have backed up and press SHIFT+D which will create an offline verison of the media, then choose delete it from disk. You can then also keep the project file and re-connect the media later if you need to.
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply With Quote
Old May 14th, 2006, 06:37 PM   #18
go it
I solve the problem with LacieD (LaCie External Drive)
I only turn off my mac once in while.
So, after the problem with LacieD, I turn off/on the mac and LacieD has all the memory bakc again. I also ejected LacieD and turn it off for a few seconds... So LacieD is ready for new files.....
Why they say in the box that the drive has 500GB. When I pluged it says that it has only 467.46GB???
By the way, I'm much better with my editing. FCP is now a breeze...
Thanks once again for your help..
JT
Janete Taylor is offline   Reply With Quote
Old May 14th, 2006, 06:54 PM   #19
go it
I love this place
Thanks guys.
