HDVXDV Issue at DVinfo.net
Final Cut Suite
Old February 2nd, 2006, 01:08 AM   #1
HDVXDV Issue
Finally, I've started capturing footage from my latest project... I captured long 16/30 minute clips
My question is whether, and TIM DASHWOOD probably has the answer, is there any formula to correct the seeming lack audio/video sync? I could always correct it by hand, but I think there's some sort of formula? Any ideas? I captured HD100 footage by the way!
Bruce Meyers is offline   Reply With Quote
Old February 2nd, 2006, 02:20 AM   #2
There's no formula. You should probably just not capture over TC breaks.
This is true with the HDV format in general. Capturing long clips is a bad idea, capturing over start/stop breaks is a worse idea.
You could take the converted file into FCP, put it on a new sequence, turn off linking for the clip (shift+L I think)use the razor blade at each cut point to add an edit, then slide the audio back into sync.
I think this would take more time than just capturing properly in the first place.
Tim Dashwood
Old February 2nd, 2006, 10:54 AM   #3
FOR TIM, HDVxDV
Tim I noticed that after capturing in HDVxDV 24fps, my footage is still in sync watching the preview window in HDVxDV, the last clip I captured was 3 min, it still remained in sync. The problem that I have encountered is when I run it through CinemaTools, watching the clip then, it's out of sync. Not a biggie, I've been syncing the footage on my on as you mentioned above. It would be nice to have this problem fixed. Do you have this same issue?
Manny Rodriguez
Manny Rodriguez is offline   Reply With Quote
Old February 2nd, 2006, 08:00 PM   #4
Manny, have you tried skipping the cinema tools step and just using your exported clips in FCP? They will be true 24fps, but they should still work fine in a 23.98 sequence, without losing sync.
Tim Dashwood
Tim Dashwood is offline   Reply
