16:9 Graphic Size ??? for .psd and .ai at DVinfo.net
Final Cut Suite
Old January 10th, 2006, 01:31 PM   #1
What size to I need to make these graphics for import into FCP if it is in
16:9?
CLEVE-ij
Cleveland Brown is offline   Reply With Quote
Old January 10th, 2006, 08:20 PM   #2
854x480 for 16:9
Dave Perry Cinematographer LLC
Director of Photography • Editor • Digital Film Production • 540.915.2752 • daveperry.net
Dave Perry is offline   Reply With Quote
Old January 10th, 2006, 10:58 PM   #3
When I create things in Photoshop to import into Final Cut for an SD 16:9 project, I use the Photoshop preset "NTSC DV Widescreen, 720 x 480 (with guides)". It creates a document that is:
- 720 pixels x 480 pixels
- 72dpi
- RGB color mode
- 1.2 Pixel Aspect Ratio (D1/DV NTSC Widescreen)
Duane Smith is offline   Reply With Quote
Old January 11th, 2006, 01:00 AM   #4
I reccomend you upgrade the project to 1080p24/30 if you plan to utilize the illustrations to make an animation. You'll get near original drawing quality editing.
Old January 11th, 2006, 01:38 AM   #5
Do you mean that PS actually has a preset called NTSC DV Widescreen. The reaon I am ask is because I was reading about and using those same settings (with the exception of the 1.2 pixel aspec ration) for projects in 4:3 and didn't have any problems.
CLEVE-ij
Old January 11th, 2006, 10:30 AM   #6
Yes, I do mean that PS actually has a preset called NTSC DV Widescreen. It's exactly as I posted. Just go to FILE --> NEW and in the dialog box that appears, choose NTSC DV Widescreen, 720 x 480 (with guides) from the Presets pop up box.
