Captured 16:9 plays 4:3 in quicktime
Happy Holidays Everyone.
I'm trying to capture some footage from an XL2 shot at 30P in FCP and of course it looks fine in FCP, but when I open the clip in quicktime, for web, etc. it is squeezed 4:3. I have had some luck with it when footage is shot 24P, but not 30P. I have everything clicked as Anamorphic, and in the advanced menu have clicked progressive and 16:9. Anyone have any ideas, or know how to fix this? Thanks, Tom |
#2 | |
-gb- |
True that you can use the player to change your screen size (but do you need Quicktime Pro for that?). But if you are putting your video on the web and want it to be in the correct proportions without any user intervention, then you'll need to set a custom frame size when you export the Quicktime movie.
Like Greg says, 854x480 would be full size. But you can use any size you like. Just make sure it's in the 16:9 proportion. So, for example, if you wanted the video to be 240 pixels high it would be 240 x 1.778 = 426 pixels wide. Of if you wanted the window to be 320 pixels wide it would be 320 / 1.778 = 180 pixels high. |
Gentlemen,
Thank you. I exported from FCP to QT with the correct size. I love this place. Merry Christmas. Tom www.take2themovie.com |
#5 |
yes, thanks for the tip.. I was scratching my head on this one as well.
Geez, you'd think as nice as QT is, it could do the stretch for us when the 16:9 flag is present! |
#6 |
Hey guys-
I've been trying to get my 16:9 footage to DVD without any success. I have a GL2 and I use Final Cut Express HD (it's basically the same as FCPHD). Anyway, I go to export it an burn it, and it's still streached to 4:3 in playback. People on the "Apple Discussions" forums say that I need to use the "Anamorphisizer" found here: http://capital2.capital.edu/admin-st...idescreen.html I, being cheap, don't want to through down $30 bucks for Quicktime Pro just so I can use that little tool... especially if it doesn't work on all DVD players like it states. Anyway, what I'm getting to is this: If I export and specify the demensions like Boyd stated earlier, will that fix my problem? Oh, and if it's for a DVD, what resolution should I use? Just asking because the original post was for Web use. Thanks! -Brett |
#7 |
What I've always done and its worked for me is make sure I capture into FCP using the anamorphic settings, do all of my editing and then export using quicktime compression with the anamorphic settings. Whenever I open up DVD studio, I have to set it for anamorphic, then import my assets. From there, it's all down hill
Bryon <>< |
#8 | |
HTH, -gb- |
#9 | |
Thanks. |
#10 | |
i forgot about that but that is true. The obvious answers always get me. I'll spend 30 minutes trying to figure out why my computer won't work before I realize it's unplugged.
Commandment #11- "Thou shalt Render as thou goest." "The fear of the Lord is the beginning of wisdom" (Prov. 1:7) |
#11 | |
-gb- |
#12 | |
-Brett |
#13 |
Just so you know the options Brett, you can still shoot and edit in 16:9 and when you're all done editing drop your finished movie in a 4:3 sequence and it will letterbox for you.
"We've done the impossible, and that makes us mighty." |
