FCP 4.5 Settings at DVinfo.net
Final Cut Suite
Old December 20th, 2005, 12:45 AM   #1
FCP 4.5 Settings
Hey everyone. Again weird things are going on with my FCP. I was wondering that I use to drag my mouse forward and backwards in my timeline and I can see the movements in realtime. Now when I do move it, it lags and not as smooth as before. Is my sequence setting wrong? I'm using 60i Widescreen on my XL2. Thanks.
PowerMac G5 Dual 2.5
2.5GB RAM/500GB/9800 256 Radeon/DeckLink Pro
FCP HD/AE 6.5/DVD Studio Pro/Motion
Canon XL2/Glidecam 4000/SteadyStick
Sony PVM-1350 Monitor
Mike Phan is offline   Reply With Quote
Old December 20th, 2005, 05:57 AM   #2
You should be capturing and setting your sequence to the "DV NTSC Anamorphic" easy preset. Take a look at these settings and then compare them to your existing clip and sequence settings. If everything is correct then you should not need to render regular video that doesn't have any effects applied to it.
You could also try the usual "catch all" procedure of trashing your preference file.
Old December 22nd, 2005, 09:36 PM   #3
Also, make sure the preview window you are using is set to "Fit" the video so that the video doesn't have to be clipped in realtime as you scrub.
Old December 23rd, 2005, 12:19 PM   #4
Also press "N" to turn off SNAPPING. That makes your playhead snap to each cutpoint.
Shane
Shane Ross is offline   Reply
