How can I import DV clips individually in Log & Capture? at DVinfo.net
Final Cut Suite
Old August 25th, 2012, 10:17 AM   #1
I'm using the following settings and the footage stretches to fill the widescreen format which is one less question I need to ask, but the 1hr DV tapes are imported together as one clip.
I want to gather all the clips from the capture scratch and store them on an external HD to edit at a later date.
Regards
Cameron
How can I import DV clips individually in Log & Capture?-dv-settings-fcp.png
Cameron Poole is offline   Reply With Quote
Old September 21st, 2012, 09:07 AM   #2
Re: How can I import DV clips individually in Log & Capture?
Use DV Start/Stop Detection in FCP 7.
Mahesh Patel is offline   Reply
