Best Sequence settings for DVD from HD & SD source at DVinfo.net
Final Cut Suite
Old August 21st, 2012, 03:44 PM   #1
G'day,
I am cutting my sister's wedding, destined for DVD, for which I used a Panny TM900 (HD) and Canon MVX430 (SD) as a static B camera.
Am I better off creating a HD sequence, and upsizing the SD footage, for it to then be compressed down to DVD quality...
Or should I use SD sequence settings, scaling down the HD footage, and being "native" size for the DVD?
Which will produce the best results?
Thanks very much
Travis
Film School ++ Showreel
Travis Wheaton is offline   Reply With Quote
Old August 21st, 2012, 04:19 PM   #2
Re: Best Sequence settings for DVD from HD & SD source
Here is one approach:
1. Load the TM900 footage into your NLE.
2. Digitally zoom, pan and crop the TM900 footage.
3. Render as widescreen DV-PAL format.
4. Start a multicamera project.
5. Cut the MVX430 footage with the DV-PAL footage created above.
The advantage to downconverting the TM900 to make it DV-PAL before beginning the multicamera edit is first, that you can do quite a bit of digital enhancement to the TM900 footage while downconverting, and second, that the subsequent multicam edit will be more responsive which allows for precice transitions and color grading.
Eric Olson is offline   Reply With Quote
Old August 21st, 2012, 07:10 PM   #3
Thanks for the feedback, Eric!
As I haven't used multicam sequences before, I wont jump into that workflow at this point, though I'm certainly interested in learning how to use multicam. (Also, as my HD footage wasn't recorded in 1 continuous block, I'm not sure how easy it will be to marry the timecodes together.)
I have read that the correct Sequence frame size settings for a widescreen DVD is CCIR 601 / DV PAL (5:4) with PAL CCIR 601 pixels, and ticked the anamorphic 16:9 box. Looks like both lots of footage maintains its correct aspect.
Thanks again for your help. As I've said, although I am a film school graduate, we only learned the basics there, and I sadly haven't had any industry experience to hone these concepts. I really do appreciate the assistance.
Travis
