Weird FCP5 issue with HDV filter handling? at DVinfo.net
Final Cut Suite
Old September 5th, 2005, 07:43 PM   #1
Hello everyone.
I'm having trouble with FCP5's handling of filters in an HDV project. I have a source clip that I can see in the viewer window, when I select in/out points and insert it into the timeline it's fine(so it's just a small piece of a larger clip)- but then I double click it to make the clip active in the viewer window and apply some color corrections- the whole source clip is becoming affected.....this wasn't how FCP4.5 behaved with DV footage as I've done this plenty of times before...am I missing something or is there a bug somewhere or a setting off?
Can't a clip be cut with a razor and modified with filters w/o affecting it's source clip? I just want the "piece" color corrected- not the entire source clip????
Thanks guys.
Steve Nunez-New York City
www.stevenunez.com
Steve Nunez is offline   Reply With Quote
Old September 5th, 2005, 10:27 PM   #2
FCP 5 Filter handling
I would make an independant clip from your in and out points and then apply the filter to that. That should solve your problem.
If anyone else has a different or better method, please chime in!
Lewis
____________________________
Fear is Faith it Won't Work Out
Lewis Lehman is offline   Reply
